04.09.2009, 08:53 PM
The motor will only draw as much as it needs, gearing and vehicle weight will determine the load.
You can run as big of a battery as you like, only downside will be the weight.
Your 7xl is a hot motor, it will pull over 95 amps, the cc2200 motor is a much better choice. The 7xl is very gearing sensitive, and 5s is too much voltage for the motor, it will most likely suffer from a magnet failure. 7xl on 4s is about as much as I suggest.
SpeedAssault
SpeedAssault's Avatar
04.09.2009, 08:58 PM
Ok Thank you
But I read that the Feigao 7xl 2383 the max amperage was 95 and could do 5S
so , you have seen/read this somewhere ?
04.09.2009, 09:05 PM
Ok Thank you
I have owned 2 of them, 4s is about all they will handle with out overheating and coming apart.
Where did you read that, on Fine Designs website?
SpeedAssault
04.09.2009, 09:11 PM
Thank you very much for your guidence.
I was hoping to get by with the Fego until I had proper cash for the CC2200
I read about it here http://www.rcuniverse.com/forum/m_6814871/printable.htm
