Thread Tools Rating: Thread Rating: 24 votes, 4.83 average. Display Modes
SpeedAssault
SpeedAssault's Avatar
04.11.2009, 05:47 PM
Originally Posted by SnoopMaxx View Post
Hyper 7 front shocks are 4.3" eye to eye
that´s 0.35" longer than the stock 3906 shocks
Hey Right awn Thank you for that
I'll check them out
SpeedAssault
05.12.2009, 11:56 AM
NEW UPGRADES
Fitting Losi 2.0 muggy Diffs inside Traxxas emaxx and Revo bulkheads
Screw the dremel to make a round tube smaller, I used my drill press and an endmill bit- 4 flut .
There is a thread on how to fit muggy truggy diffs in your revo or maxx but it consisted of a lot of hand held dremel time and ugly finish
With using a Drill press you get a precise cut and finish in 2 minutes !
Here is how I did it, Lath process with a drill press !
1" Hose coupler at hardware store $.99.
cut off an inch or so and find a socket that fits snug inside
then clamp the the socket in the vise of the drill press so that you can rotate the coupler by hand
use a 1/2" endmill
then measure how much needs to be trimmed down. I eyeballed it then checked with a caliper.
turn on drill press and bring down bit and then just start slowly turning the the plastic tube to cut all the way around.
I made 4 pieces in less than 15 minutes
ID:	6968   Click image for larger version
ID:	6967   Click image for larger version
SpeedAssault
05.12.2009, 11:59 AM
more pics
you can use the same endmill bit to cut down the traxxas diff collar to fit onto the losi diff housing also
ID:	6971   Click image for larger version
ID:	6972   Click image for larger version
SpeedAssault
05.12.2009, 12:05 PM
First pic
I cut the stub axles to fit the Losi side diff gears and still use Revo axle shafts
I replace the stub wheel axle with new titanium stubs.
To make Lockers for the diff and the new Losi muggy center Diff I cut a piece of aluminum and Delrin to fit inside the carriers which ties the left/right outputs to the ring gear
(note: I used Delrin because it was easier to cut and sand down in the belt sander and it was lighter by a tad.
using the Alum one for the Center
ID:	6975   Click image for larger version
ID:	6976   Click image for larger version
SpeedAssault
05.12.2009, 12:24 PM
More parts
Losi Heavy duty Differential cases
Aluminum covers
Losi 8ight front shocks
total length 68-97mm about 3 7/8"
Losi Aftershock driveshaft , cut it in half and added a stainless tube and will be welded in.
ID:	6978   Click image for larger version
ID:	6979   Click image for larger version
05.12.2009, 12:26 PM
Nice looking adapter! I had a piece of sch 80 turned down to match the large ID on the bulk. And then had it paired off to the correct width. I did not bother to make the little step like you did, as I saw no need for it. Modding the front pinion support takes a bit of work, you need to turn the inside out to the OD of the nose of the lst case, then clearance the back of the collar to get it to fit against the lst case.
05.12.2009, 12:28 PM
I also like the sectioned lst driveshafts. I see that you sleeved them, did you also weld it too?
SpeedAssault
05.12.2009, 03:40 PM
hey thanks lincpimp, -what does that mean?
Yea , I thought I took pics, guess not. I did forget to mention I did use a dremel to enlarge the inside of the collar, then a file to even it up.
Yea once I make my CD / motor mounts I will decide on length needed for the front and rear shafts, Then Weld them
05.12.2009, 03:47 PM
Sounds like a good idea on the center driveshafts. The pipe I found had the correct ID, so all I had to do was turn the outside down to the correct OD.
lincpimp came from a bunch of us picking up chicks with an old lincoln towncar that I used to own.
SpeedAssault
06.04.2009, 12:33 AM
Hey guys what do you think,
time to place the motor and tranny and weld up the shafts so would you say mount all the way forward or partially ?
Also
I'm thinking I should mount motor all the way up front and slightly to one side and use the 6s lipo on opposite side to counter the weight, On the other hand mount motor in center 1:5" above chassis
I like the look of centered but offset gets it lowest CG, what do you guys think ?
Got the motor/tranny mounts finished but having second thoughts
Built it so the motor is just slightly off center but close to the bottom.
ID:	7203   Click image for larger version
ID:	7202   Click image for larger version
