rcjmaxx
04.13.2009, 12:05 PM
Heres what I got...OFNA GTP onroad sedan, 8 1/2 lbs with 6s ready to run.I'm looking for at the least 70 mph without hurting my Trakpower hard pack 4900 and/or 5400 cells. Which would you advise 2700 or 2200?
04.13.2009, 12:39 PM
either will work for what you want, and everyyone will have their own opinion what to use. for me, if I can physically fit the gearing for the desired speed with a lower kv motor, then I use the lower kv motor. use the speed calculator and figujre what gearing you need to run for each to get your 70mph and then take a look at what you have, what you need to get what you want, and what will fit. most of all, have fun
