04.14.2009, 09:36 PM
There are different and will not work together different frequencies
04.14.2009, 09:39 PM
And some other fun things to think about... There is both fm and am 27 and 75mhz... So you first need to find out if you are running am or fm.
But in the end, 27mhz xtals will only work with a 27mhz radio and rec. Same with 75mhz, so no swapping!
04.14.2009, 09:49 PM
YEAH, YEAH but that is about the extent of my radio knowledge. I'm going with an Airtronics MX-3FG FHSS2 so I won't have to worry... much. (I have researched this a fairly good deal.)
04.14.2009, 09:59 PM
I've used am and fm xtals interchangeably. 27's and 75's wont match, but am 27's will match fm 27's and vice versa, and it is the same for am and fm 75's. As long as the 27.xxx numbers match they will work. It is the same frequency, they just use different methods to get there.
04.14.2009, 10:05 PM
Do you ever do anything right? HAHA
Anyways that is true, you can swap the crystals from am to fm if the frequency is the same.
04.14.2009, 10:15 PM
See, I learned something new today!
04.14.2009, 09:55 PM
This along with what Magman said pretty much answered everything. I hope! Brian will let me know soon enough if not.
Thanx,
Zack
04.14.2009, 09:44 PM
So if a radio system says for example 75mhz on the cases you cannot use 27mhz crystals?
Don't forget to tell him to join.  Seriously
04.14.2009, 09:57 PM
Originally Posted by kcaz25
so if a radio system says for example 75mhz on the cases you cannot use 27mhz crystals?
join rcm tonight!...WHAT ARE YOU WAITING FOR
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
