Patrick
Patrick's Avatar
04.15.2009, 05:07 AM
I don't think many people here will be using the capacitors, because I don't think many people will be using brushed motors, but as far as I know the capacitors are only there to reduce radio interference. So if you are using the motor in a lathe you won't need them, but if it's in a crawler or something then you'll probably need the capacitors. You might not need them with 2.4ghz, but I'm not really sure, someone else might know about that.
rchippie
rchippie's Avatar
04.15.2009, 07:24 PM
I need 6 motor capcitors for my two 45t crawler motors . Does anyone have 6 capcitors they can spare ?.
REAL MEN RUN BRUSHLESS
rchippie
rchippie's Avatar
04.16.2009, 07:41 PM
I found some capcitors .
