gixxer
gixxer's Avatar
04.16.2009, 02:10 PM
Very nice. Figured someone from here would get it. Was kicking myself for not bidding at the end what I saw the price it went for. Should be about the same when it actually hits the states though. Nitrohouse has them listed for $449.
Anyways how long is the battery tray? I ordered a neu 4300 6s pack and want to make sure it will fit. Also what size is the spur? I assume it will have a 40t like the nitro? Hoping larger will fit cause I really would like to put in a slipper or losi smartdiff?
thanks
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
Marvin
THE Paranoid Android
Marvin's Avatar
04.16.2009, 02:23 PM
Yeah, to be honest it should go to someone from the UK, because what I got it for was about Trade price + VAT (predicted), RRP would have been about $650 (equivalent). You get stuff so cheap in the US!
The battery tray is 175mm long (might stretch to 178mm - that is absolute maximum though!). Width is 46mm and you can have practically any height due to the bodyshell design.
Spur is a 40T, and you could fit probably up to a 44/46T in there - main problem though is that it uses very small diff cases (short ones), you'd be hard pressed to fit a bigger one in there - it also uses small outdrive bearings.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
