Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
nusti
nusti's Avatar
04.16.2009, 02:32 PM
thanks, just sent the mail again. I hope they will reply.
superek4
superek4's Avatar
04.20.2009, 07:13 AM
Managed to get a latest version of hobbywing 150 esc tested in my 3rd race.
1st heat software problem car has max drag brake, managed to reset.
2nd heat batt died, I used a 4s 5000 zippy set 4s manually on d esc but still one cell died. Dunno izzit batt problem or esc
3rd heat completed with no problem
At the Main batt pop out becoz it was a 6s n was not secured properly, fix n tried to run then found out d switch was cut by my spur gear. Tried to connect the black n red wire but can't start d esc. Din want to try d white wire in case the esc gets burnt.
So far I m ok with d esc change all setting except punch, esc ran cool. Need to find out how to undo the drag brake though.
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
littlegiant
04.20.2009, 07:45 AM
Did you play around with the timing? how did you get the lastest firmware version?
