azjc
04.17.2009, 02:22 PM
Originally Posted by Joey View Post
I used this speed calculator:
http://www.scriptasylum.com/rc_speed/_top_speed.html
Not sure how you got 43 mph on a CD, 48 spur, and 18 pinion at 33000 rpm!
i thought you had a tranny...sorry
I did have your setup at
1300kv motor
5s lipo
52 tooth spur
18 tooth pinion
this got your speed down to 44 mph
04.17.2009, 02:26 PM
You definitely need a larger spur... Or more reduction in the diffs. A motor that spins around 30k rpm is fine if you are geared for 40, but geared for 50 you will have a ton of startup load, and you may have issues...
04.17.2009, 02:57 PM
maybe 2.2 tires
Joey
The Big Cheese
Joey's Avatar
04.17.2009, 03:21 PM
1300kv motor
5s lipo
52 tooth spur
18 tooth pinion
No prob Azjc :) Didnt mean to come off sounding rude.
The larger spur is the way to go. But again... what spurs will fit the 8ight/8ight-t CD? The ones I find that are made for it only go up to 50T. Are most 8th scale spurs a "universal" fit with each other?
04.17.2009, 03:31 PM
The 8ight uses 8x14 bearings, and the diff cup looks to be very similar to a ofna/hb cup... I am not sure if the mount holes will line up, but a crt spur, 62t, will accept a bearing with 8mm id and should not be too thick. Do you have any pics of you mounts?
Joey
The Big Cheese
Joey's Avatar
04.17.2009, 04:15 PM
