MetalMan
MetalMan's Avatar
04.18.2009, 12:04 AM
Okay, running the numbers...
CEN Genesis has 9/26 diff ratio, correct? And let's say 7" tall tires (even if they are taller than that). 2200kv, 14.8v, 19/46 spur/pinion gearing.
Assuming the numbers I listed are correct, you were geared for a solid 90+mph. No wonder the MMM died.
Even if you could fit a 10t pinion, you would still be overgeared at 50mph.
