Semi Pro
Semi Pro's Avatar
04.19.2009, 03:45 PM
I use S3 o-rings on mine.
best way i have found too
04.19.2009, 03:49 PM
I cram old pieces of bubble gum in the cups and then duct tape the outsides. I also like to wrap duct tape on the tires as it keeps the road from wearing the tread down. These are all good tricks, I will think of more and write them down. Wrapping duct tape around the motor is also good to keep the heat in (heat = power), why waste it!
Semi Pro
Semi Pro's Avatar
04.19.2009, 07:24 PM
good stuff
you could also save money by filling your shocks and diffs with pudding (its alot cheeper than silicone oil and tastes better too)
stop buying expensive tire foam, you can fill alot of tires with just one can of great stuff foam
04.19.2009, 07:42 PM
good stuff
Good tips, I like to stuff the tire foams down my pants... I get alot of "attention" at the club with that trick!
Seems like the molded foams don not fit as well though...
Mayo would be better in shocks, IMO. That way when you pop one it would look really funny with the white stuff dripping off it.
brushlessboy16
brushlessboy16's Avatar
04.20.2009, 07:44 PM
Well the guy at my lhs told me that ketchup is a good substitute for 30w oil (true story) so mix up your condiments to tune your suspension :)
JThiessen
JThiessen's Avatar
04.21.2009, 11:32 AM
LMFAO!!!!!!!!
In regards to cups fitting/dogbones. I was helping my B'in law put together his new to him Emaxx FLM chassis. Magman, maybe you can help here - it came with what I believe to be a UE dogbone for the rear. However, it didnt have any cups with it. I happened to have a set of bent UE shafts, so I gave him a set of the cups for it. However, it ended up being just a little on the tight side. So I took apart one of his Traxxas center dogbones, and it was a perfect fit - suprised the heck out of me. I'm just not certain what brand of shaft came with the FLM.
