Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
mothman
04.20.2009, 03:35 AM
Wow!! It looks really great and I bet those who intend to put the Slipperential in their Savage might be interested. But I think its going to cost a lot to get this case fabricated..
Dafni
Dafni's Avatar
04.20.2009, 06:40 AM
We are building a slipperential savage. With parts from Mike. If you want I can post some pictures....
cheers
Daf
Finnster
KillaHurtz
Finnster's Avatar
04.20.2009, 12:24 PM
cheers
Daf
Hey Daf! that would be great. I was planning on a CD/Slipdiff Savage too, but I don't have the time and tools to get it all done properly in any time soon (may or may not have seen my thread.)
Question tho, are you planning on a direct drive unit, or some sort of gear reduction (ie a one spd tranny, like some of the first version slipperentials?)
That was a big stumbling block I was running into. A big spur hangs out the bottom or has to have unfriendly driveline angles (for high mounting.) Likewise, a small spur fits nicer, but offers little gear reduction, even with a small pinion. EG, w/ a 10T pinion & 46T spur, on the stock diffs you only get a ~15.9:1 FDR. Not much if you have a heavy savage and big 40 series tires.
Forget about running the Cen diffs w/ their 2.89 ratio. G/L, I hope to see what you come up with.
spiftacu1ar
04.20.2009, 01:09 PM
The savage with 40 series wheels, CEN diffs, and 50:9 slipperenital/pinion garing yield about the same reduction as the stock flux with the stock 44:25 gearing
Finnster
KillaHurtz
Finnster's Avatar
04.20.2009, 04:00 PM
I can't see your pix here, but I'm excited to see them later, sry for the hijack :)
When you say 44:25, are you talking spur/pinion? or the internal tranny gears? I assume the former, which is still quite low (~16:1), but workable. Only bad part would be the rapid wear on such a sm pinion. G/L
spiftacu1ar
04.20.2009, 05:48 PM
I was talking about the spur pinion. The flux stock with 44:25 spur:pinoin is about the same as Big joes, Cen diffs, and 50:9 (slipperential pinion) ratio.
