rchippie
rchippie's Avatar
04.20.2009, 11:28 PM
I shoot the basecoat with a hvlp gravity feed gun, but stick to a conventional gravity feed for the clear coat. Spray the clear at 60psi, so it atomizes well. Wastes a bit more paint but you can move faster... Both are sata guns, and both cost well over 600 each. Worth every penny, had one sata for 13+ years and just had to retire it from everyday use.
What is your reason for two different guns, personal preferance or better control for the difference in viscosity of paint & clear coat ?.
REAL MEN RUN BRUSHLESS
04.20.2009, 11:57 PM
I actually have 4-5 guns. One for primer, one for sealer, one for base, one for clear and a mini jet for spot repair/small areas. And I have an airbrush too.
All have different sized needles and all spray a certain type/viscosity paint a certain way. Plus with a gun for each product you do not have to work about contaminating different paints, and you can use a cheaper gun for primer and sealer, and replace those more frequently as they wear out faster.
