View Poll Results: Do you want new switches
Yes 76 84.44%
No 14 15.56%
Voters: 90. You may not vote on this poll
04.22.2009, 02:33 AM
My switch is mounted facing up. with the slider at the top perfectly vertical and a landing shut it off. no side-to-side motion on the truck at all
if landing a jump is shutting it off then its a switch position problem, not a switch problem. moving the switch would cure your problem.
I believe the switch should be mounted in the esc case. There are enough things to mount, and enough wires.
