Sylvester
Sylvester's Avatar
12.18.2005, 01:06 PM
Papa, your truck is by far the nicest ive seen in a while, the way you set it up and put it together, id reccomend you lower it a bit if you are going to race it which i think you are. Edit** i also think you should put the motor in the middle position on the motor mount to distribute weight evenly around the truck, unless your using lipo on the other side?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
