04.22.2009, 05:02 PM
Depending on how patient you are, making your own shouldn't be too difficult if you have the material. The hardest part would be to drill the holes accurately.
By the way, I thought I had stripped one of my Medusas as well, but it turned out the 3mm screw I was using was smaller than it should have been. Seems that there is a lot of leeway allowed when making a 3mm screw. Also, how deep is the screw going?
