Edumakated
04.23.2009, 11:29 AM
Originally Posted by Thomas View Post
Hi there,
I've been reading about conversions and doing calculations for over a year, but now when it comes to ordering, I'd like to get some advice from experienced users.
I'm going to convert my TTR S3 to electric and have chosen 6s Kokam 2400 mAh 30C batteries. For the motor, I was set on the Tekin Neu 1509/2Y/f with 1820 kv. This will spin around 40k RPM on the straight, geared to go just a tad faster than the nitros (using truggy bevel gears).
But, Tekin is recommending this motor for 5s and the 1509/2.5Y with 1450 kv for 6s.
I'm now in doubt which motor is better for me. I thought the Neu motors could handle 40k RPM easily and since the 2Y needs less torque with the shorter gearing, should run cooler instead of hotter. I want sufficient power for racing and long run time (efficiency).
Which motor would you choose for 1/8 buggy on 6s, 1509/2Y or 1509/2.5Y, and why?
Thanks for your help.
Thomas
First, skip the 1509 for a 1/8 buggy. Been there, done that, and got the t-shirt. It will run a little hot. not saying it won't work, but your gearing will need to be PERFECT. You are much better off with a 1512 sized can.
In my experience, I find the Neus to run most efficient at around 31,000 rpm, at least for racing. You can easily run a Neu up to 60,000 with no problems though. I have run a 1512 1.5d on 5s with no heat probelms. I have also raced that same motor on 4s (49k) with no heat issues too.
However, I have found I get the best run time when I keep the rpms right around 31,000 rpm.
Andrew32
04.23.2009, 11:51 AM
1/8 scale i would run a 1515 series motor personally
Keep your RPM range close to 40k and youll be fine.
