hpitraxx
hpitraxx's Avatar
04.24.2009, 02:46 PM
hi unsullied spy looks like you have used quite a few different motors whcih would u recommend?
Unsullied_Spy
Unsullied_Spy's Avatar
04.25.2009, 05:33 AM
It all depends on what you are putting it in and what kind of power you want. A 2650 in an E-Revo will be plenty powerful and, IMO, better for racing because it'll be more controllable. Sure you can dial down the throttle curve and do a bunch of other fancy tricks to cut back power but an ESC is the most efficient at 100% throttle because that power can bypass the FETs altogether, resulting in a cooler ESC. From what nitrostarter says, I should be making some sense
I ran a 1515 1.5D on 4s lipo in my Revo 3.3 conversion and it would scaree the crap out of a person. It' basically the same motor as the 2200 but higher KV, and it would spin all 4 Talons on ashpalt until they finally hooked up and flipped it (I did get it to backflip a few times, seeing a full-size Revo backflip is exciting but tough on parts). You can't really go wrong with either setup in the E-Revo, it all depends on what you're looking to get out of it.
