SnoopMaxx
SnoopMaxx's Avatar
05.02.2009, 07:42 AM
Update on the Tranny modification to mount 3905 steel idler gears in the 3906 tranny
2nd gear Idler is grinded down to 11mm
1st gear idler is 13mm wide, total with on bracket is 38.4mm
Idler shaft bracket is filed down to 17mm so the idler gears can spin freely
Morten SnoopMaxx
Never to old to play
c",)
Different.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Different. - 05.02.2009, 09:09 AM
On one of mine I just took the dremel and removed a few thousanths of an inch off the case where the idler shaft bearing sits. Everything rolls like a charm. I have the RC4WD aluminum tranny 1st & 2nd gears in it as well.
SUPERMAXX YOUR LIFE.
