Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Ryu James
Ryu James's Avatar
05.02.2009, 12:44 PM
Originally Posted by ANGRY-ALIEN View Post
Hey Neil, thanks for the suggestions man... I will get some tests done to see how the Carbon reacts to the laser.
Alien
hey dude,
DONT USE LAZER TO CUT CARBON. i have been building some custom carbon chassis over the past few months and i initially tried laser to cut them out as it was going to save me money. the cuts were straight and everything but what happens is the laser melted the epoxy ever so slightly along every cut made. this caused the fabric to be frayed really bad along every cut and the the part looked like shit. also, the frayed fabric gets in your skin like fiberglass and is horrible to try to work with after that.
i just use a CNC shop to cut all my carbon now and it is 10x better. save yourself the trouble. idk, i have heard of people using laser to cut carbon successfully so i dont know if the piece i had cut was inferior or what but since then i have used the same carbon cut on the CNC for my 1/8 brushless truggies and have been racing with them for weeks without any issues. and this is only 3mm carbon so i would say it is decent carbon to hold up to the abuse i have given it.
pm me if you have any other questions. i have been working with custom carbon stuff for the past 6 months and can maybe help you out with any more questions.
Jammin SCRT10 Neu 1512 1y
lutach
lutach's Avatar
05.02.2009, 12:56 PM
Has anyone thought about waterjet?
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
05.02.2009, 01:15 PM
hey dude,
Hey Ryu, Thanks for sharing your experience man, I'll have to go search for someone here in Jamaica with the appropriate CNC machine to get this done right then...
The same company with the laser might have one. The other problem is, if I do find them, it's hard to convince the shop to try a material outside of the list they may already used for their business.
Hi Lutach, no waterjets here so far... So that's not an option for me right now.
Alien
lutach
lutach's Avatar
05.02.2009, 01:36 PM
Alien
Ok, all I know about carbon fiber and high heat is that carbon fiber burn pretty good. I've heard of people using a CNC machine and placing the CF under some sort of liquid to avoid all the harmful dust. If the same can be used with the laser then it might work.
Ryu James
Ryu James's Avatar
05.02.2009, 03:53 PM
i started out using a dremel tool with carbide tungsten bits to make my own carbon parts. then i found a CNC shop to do stuff. just make sure they use carbide tungsten bits. all other bits melt. also, the dust is extremely harmfil to breathe so you need to wear a mask when doing work with carbon. and i think it is better to run the bit at the slowest speed possible that still cuts efficiently. going faster only melts the bits or the carbon. i have found a slow speed cuts much better.
as for waterjets i havent tried it but i have heard that it also frays the carbon resulting in a very ugly part and one that most likely cant be used.
CNC is the way to go but may require some experimentation on your part.
there are some CNC shops that work with carbon all the time and really have a good system down of how to do it best. i have yet to find one locally but look around as i know there are shops that specialize in working with carbon and have already gone thru the trial and error.
ANGRY-ALIEN
05.02.2009, 05:10 PM
Thanks for all the help guys... Here's a little preview of what I am working on.
Alien
05.02.2009, 06:05 PM
That is a very pretty maxx.
