Alright. I will try to get as low CG as possible, with them as far front as I can...
I noticed stock Flux gearing is 25/44. Seems a bit high. Could that be right? It's what it says in the Flux manual. And I will be running the same setup... (6s, 2200kv mmm)
Go with a 17t pinion for 6s usage, the manual is wrong. It lists the 25t pinion for use with phatline tires for the max speed.
