zoomer
05.12.2009, 07:06 AM
1) Stepping voltage converter vs linear - you can google the difference but stepping is more effecient hence less heat
2) yes no issue
3) remove red wire from ESC into RX - Bec can go into any slot aux/bat etc... with a couple of fans you are going to need a splitter of some kind
hi arct1k, thanks for your info mate great help, ok with the speed controll i have to remove the red wire, please can i ask why, i'm very new to elec(used to have nitro).
also whats a splitter you mean Y harness, if not can you give me some links please.
thanks in advance cheers tony...
