Thread Tools Rating: Thread Rating: 24 votes, 4.83 average. Display Modes
SpeedAssault
SpeedAssault's Avatar
04.09.2009, 08:18 PM
Need some more help on Motor and battery
Is a 95amp max Feigao 2383 motor ok to use with a 160 amp battery ?
Looking at buying Two 5s 1s1p 3200XP 25c and putting in Parallel = 5S 6400 128 amps.
Or should I get a castle 2200 before I blow the Feigao 7XL ?
04.09.2009, 08:48 PM
The feigao will get hotter than the castle motor. Hot stuff can draw more amps. The castle motor is more efficient, so it will make better use of the available power.
The 160 amp lipo will do fine with either motor. The 6400 5s 25c lipo is good for 160 amps cont, not 128amps.
SpeedAssault
04.09.2009, 10:10 PM
I think your right. There is another guy that responded to same question but said the Fago cant handle 5s it will burn up the magnets
I do want the CC but I have noticed there are Black 2200's instead of the green. so I'm trying to figure whether to buy a MMM for $140. and try to get the black one for under $120.
a new combo with green motor is $158. delivered
SnoopMaxx
SnoopMaxx's Avatar
04.10.2009, 01:32 PM
The black motor is from the E-Revo BL
BTW Cool ride
Morten SnoopMaxx
Never to old to play
c",)
SpeedAssault
04.10.2009, 02:42 PM
BTW Cool ride
Cool thanks, that's what I'm hearing. was going to verify with castle today but they are closed for Good Friday
Think I'll bid on the black one, just not liking the green
Thank you for the Compliments
some latest pics
Losi Aftershock Diffs
Losi 2.0 truggy Front shocks are really nice, but I was misinformed about length. they are sopposed to be longer than Losi 8ight shocks, but in fact these shocks sopposedly 2.0 frnts are 3 /34" so I'm trying to find out what shock is 4" or between 4 and 4.5"
Been eyeing the INtegy revo upper arms to swap in for upper only
but both look so good it's tuff to decide. so I printed them out and put them on the car
what ya think ?
tape on tires to help see what the actual new tire width size will be
ID:	6785   Click image for larger version
ID:	6786   Click image for larger version
mjderstine
mjderstine's Avatar
04.10.2009, 03:35 PM
which ones are which? if i were you, i would stay away from the integy ones, i haven't heard good things about the quality of the Al the use.
SpeedAssault
04.10.2009, 07:42 PM
Yea I know Aluminum is not as durable as the stock or RPM, I was just going to do the uppers.
The Large arms that allow shock inside are (Integy) intt3122s for revo rear
the smaller sleeker ones are (integy) t3203, revo front but unlike the 3122 these do not have nylon inserts
SnoopMaxx
SnoopMaxx's Avatar
04.11.2009, 03:43 PM
Hyper 7 front shocks are 4.3" eye to eye
that´s 0.35" longer than the stock 3906 shocks
Morten SnoopMaxx
c",)
SpeedAssault
04.11.2009, 05:47 PM
Hey Right awn Thank you for that
I'll check them out
SpeedAssault
05.12.2009, 11:56 AM
NEW UPGRADES
Fitting Losi 2.0 muggy Diffs inside Traxxas emaxx and Revo bulkheads
Screw the dremel to make a round tube smaller, I used my drill press and an endmill bit- 4 flut .
There is a thread on how to fit muggy truggy diffs in your revo or maxx but it consisted of a lot of hand held dremel time and ugly finish
With using a Drill press you get a precise cut and finish in 2 minutes !
Here is how I did it, Lath process with a drill press !
1" Hose coupler at hardware store $.99.
cut off an inch or so and find a socket that fits snug inside
then clamp the the socket in the vise of the drill press so that you can rotate the coupler by hand
use a 1/2" endmill
then measure how much needs to be trimmed down. I eyeballed it then checked with a caliper.
turn on drill press and bring down bit and then just start slowly turning the the plastic tube to cut all the way around.
I made 4 pieces in less than 15 minutes
ID:	6967   Click image for larger version
ID:	6968   Click image for larger version
SpeedAssault
05.12.2009, 11:59 AM
more pics
you can use the same endmill bit to cut down the traxxas diff collar to fit onto the losi diff housing also
ID:	6971   Click image for larger version
ID:	6972   Click image for larger version
SpeedAssault
05.12.2009, 12:05 PM
First pic
I cut the stub axles to fit the Losi side diff gears and still use Revo axle shafts
I replace the stub wheel axle with new titanium stubs.
To make Lockers for the diff and the new Losi muggy center Diff I cut a piece of aluminum and Delrin to fit inside the carriers which ties the left/right outputs to the ring gear
(note: I used Delrin because it was easier to cut and sand down in the belt sander and it was lighter by a tad.
using the Alum one for the Center
ID:	6975   Click image for larger version
ID:	6976   Click image for larger version
SpeedAssault
05.12.2009, 12:24 PM
More parts
Losi Heavy duty Differential cases
Aluminum covers
Losi 8ight front shocks
total length 68-97mm about 3 7/8"
Losi Aftershock driveshaft , cut it in half and added a stainless tube and will be welded in.
ID:	6978   Click image for larger version
ID:	6979   Click image for larger version
05.12.2009, 12:26 PM
Nice looking adapter! I had a piece of sch 80 turned down to match the large ID on the bulk. And then had it paired off to the correct width. I did not bother to make the little step like you did, as I saw no need for it. Modding the front pinion support takes a bit of work, you need to turn the inside out to the OD of the nose of the lst case, then clearance the back of the collar to get it to fit against the lst case.
05.12.2009, 12:28 PM
I also like the sectioned lst driveshafts. I see that you sleeved them, did you also weld it too?
