Patrick
Patrick's Avatar
05.13.2009, 06:56 AM
I wouldn't suggest doing it, but it would be interesting to see what it actually would do in the real world. As the 2550's start losing voltage the 3250's should charge the 2550's back up a bit, since voltage between parallel cells should be even. Could have an unhappy ending though.
I have seen strange lipo setups used before with no issues though. 6 cell nimh (I think IB4200's) in series with 4900 mah 2s lipo. 4900 mah 2s in series with 4000 mah 3s of diferent C rating and brand. 25c 5000 2s venom pack with venom 4000mah 20c 3s pack, and a couple of others similar to that. I think the main thing is not to discharge the packs to far, 5 min races didn't hurt them.
Still don't recommend it though, especially when going for maximum runtime.
Do the packs need have certain dimensions? Can you fit 2x 3s 5000 - 6000mah packs in series.
Marvin
THE Paranoid Android
Marvin's Avatar
05.13.2009, 07:38 AM
No, not really, they need to be quite short, and most large capacity packs are long. Also, I would like to stick to Flightpower, as they are the best manufacturer at the cheapest price in England. (Polyquests and stuff would end up being more for the same cells, just because of the distributors).
Admittedly, there are the Trakpower 5400mAh 'Traxxas' packs, which are 11.1V, but they are only 16C, so I think I may be pushing it there.
I've looked at different set-ups, and two 5S 3250mAh packs in parallel should give me about the run time I need, but still aren't too heavy.
Besides I don't have to risk the MMM on 6S (though most don't suffer from this, but I'd still like to stay on the safe side).
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
