E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
05.13.2009, 09:59 AM
12 1/2 lbs is a little heavier than my e-REVO ready to go. If that is your weight ready to run I think your going to need a massive motor to keep things cool on a 90* day trying to hit 55MPH. On the hottest days my 1515 2.5df gets a bit warm with gearing for 40mph on 5s. I'm sure the tekin ESC will be fine but I don't know if their motorwill be enough. Maybe a 1518 or 1521 neu or 80mm medusa would be a better choice. Or you can be a little more reasonable with your speed requirement and gear for 35-45MPH. I honestly think 35 is plenty to have fun with, pushing to or past 40 creates a lot of O shit moments.
B4maz
05.13.2009, 10:14 AM
The only thing I can see wrong is how hard you drive it and if the gear mesh is too tight. If you are always accelerating 100% and using the brakes constantly I can see where it might cause problems.
Your setup is very similar to Joe Fords setup he has for a Kyosho GT2 for speed runs (100mph+). You can check all the details and videos here. It sounds like you need to let the car cool down. Joe's car probably weighs a little less than yours. maybe 10lbs.
This is his setup:
6s 5300 30C
2200kv Monster Max combo
2 speed transmission
This is what he said:
With the gearing I am running and current it is drawing the motor does need some time to cool down between runs (but it's ok...so do my nerves!). If I can get a handle on all the power the 2200kv system provides I'll be going up to the 2650kv motor with the same battery and gearing. It's currently geared for about 140mph, the 2650 would take it up to about 170mph according to Mike @ RCM.
