FG101C
05.15.2009, 02:33 PM
Originally Posted by Cain View Post
Did you go through the diffs? do they have the upgraded o-rings?
Yes, I did the front and rear diff's, as far as I can tell the o-rings are good, just like any other diff's I've done. They do use a gasket type seal between the ring gear and diff cup instead of the o-rings like on the 8.5 and ST, plus the diff's are alot smaller than any other 1/8th diff I've seen. So no slipperential for the 9e
SnoopMaxx
SnoopMaxx's Avatar
05.15.2009, 02:48 PM
Plz post photos
I'd like to see the 9e diff next to a nitro diff
Morten SnoopMaxx
Never to old to play
c",)
FG101C
05.15.2009, 02:52 PM
When I get to the center diff I will post pics, front and rear are back in already.
SnoopMaxx
SnoopMaxx's Avatar
05.15.2009, 03:52 PM
Can't wait
Are the hyper 9e diff gears the same size as the nitro hyper 9
Or is it just the diff cup that is smaller ?
Morten SnoopMaxx
c",)
05.15.2009, 04:22 PM
The cups sorta look like the crt.5 cups? Anybody with a 9e manual handy to check the p/n?
76Bentley
05.15.2009, 04:51 PM
Ofna lists the cups as 29003.
I am looking forward to this buggy, I am really happy to see a company leave the nitro heaviness in tact but rethink what could be a better lay out for electric.
Anyone have a pinion size they would suggest for this buggy with a 2200kv MMM set up on 4s? Would like to be up in the mid 40s mph range and keep things cool. Thanks for the input in advance.
FG101C
05.15.2009, 05:52 PM
The buggy comes with a 14 tooth pinion, 40 tooth spur and 43/11 internals. Internal gears are the same size as any other 1/8th.
