Go Back   RC-Monster Forums > Support Forums > Team Tekin
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
05.17.2009, 10:22 AM
The wiring looks correct. I am sure Tekin will take care of you, but I am curious about a couple things myself.
Do you have a hotwire? If so, does it work? And if it works, what are the settings on the esc?
When you pulled the trigger and it didn't go, that should have been a clue that something was wrong. Did the ESC arm itself when you turned the switch on? If it was in the wrong "motor mode", there should have been LEDs 1, 2, 6, and 7 flashing(error code). Once armed, the LEDs should ramp up and down when you apply and release the throttle(and if a motor is connected properly, it should accelerate and decelerate).
If itl et out smoke, it is a mute point I guess, but I am Sure Tekin will be curious to know the chain of events that lead to the smoke for trouble shooting purposes.
