nitrostarter
nitrostarter's Avatar
05.18.2009, 12:54 PM
Originally Posted by BP-Revo View Post
Also, the gear ratio's of the new V3's are slightly higher than the stock Revo diffs. Before, I had perfect gearing running 4S. Now I am going to be switching back and forth from 5S to 6S. I was figuring I should leave the pinion be and I should be ok.
What do you guys think? Should I drop a tooth on the pinion to be safe?
Any other comments welcome.
What is your current gearing? Try running the numbers on the speed calc and them switch the diff ratio to :Typical Buggy" ratio and then regear accordingly to achieve the same speeds.
N. Rustler conversion
