JThiessen
JThiessen's Avatar
05.20.2009, 06:23 PM
my 2S2P's were too wide (by about 1/2" or so). But they fit length and height wise.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.20.2009, 06:49 PM
So in other words, it can't be done with 14 M1 cells... bummer.
Does a 4 cell stick pack of M1 cells fit? Like a double shotgun pack, two-by-two? I'm guessing 4 cells on each side like this is the max you can technically fit in it?
This would work great actually, if only a controller could handle the extra 3.3volts @ 26.4volts... has anyone experimented with the MMM on voltage capability? Because we all know the MM could do 35% more than rated!
zeropointbug
Z-Pinch racer
05.20.2009, 07:01 PM
I do need a new controller this year, what about the RX8? Can it handle 26.4volts?
05.20.2009, 07:27 PM
The MMM is said to work on 7s a123. I haven't tried it myself though.
