BUSAFIED
05.20.2009, 08:56 PM
Originally Posted by crazyjr View Post
The neu was probably ok, was it a 1515/1.5d? I was refering to the tekin motor, the 2650 is designed for the buggy not the truggy, its even listed on tekin's site as such. The highest kv motor on the truggy list is the 2200kv, Size wise, the truggy motor would be better at handling the load
As far as the temps, you seem to be ok. I was refering to the tekin motor being a buggy motor, you even said it run a bit warmer over the neu, I think it was because it was a smaller (shorter, as in a 1512) motor than the neu
affirmative...the motor is 1515/1.5D/F. Don't recall where I said the T8 ran warmer than the Neu...in fact, the temp was lower. 123F, if I remember correctly. :)
I have one last test remaining for the T8...if she fails to perform, it's off to the chopping block for her.
crazyjr
crazyjr's Avatar
05.21.2009, 12:54 PM
You were right, I misread the temps. I still think part of the problem with the tekin motor, is its designed for a buggy, so less power available and less torque from the input
BUSAFIED
05.21.2009, 09:57 PM
aaah....I see! So...the lower the KV, the higher the torque and the bigger the can.
So if I wanted a stupidly powered buggy, then I should use a truggy motor in my buggy, aye?
Well, well...we shall see. Looks like I might hafta sell the 2650 and pick up a lower KV T8.
