E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
05.21.2009, 12:19 AM
Also take a look in the RC-Monster store. I'm running some 4500mah 5s packs from Mike in my truggy. I must say that if you are going to race the 2200kv on 5s might be a bit much, use BrianG's speed calculator and enter in all the info and see how small of a pinion you will need. My RC8T has a 54t spur and I would need like a 11-12t pinion to get usable speeds on the track with the 2200kv. I run a 1650kv on 5s geared for about 38, I can pull away from any of the nitros(now I need to work on my driving). The NeuEnergy Lipos are a very good choice for the money as well, I run some of them in my E-Revo in a 5s setup.
A tekin rx8 combo may be a better choice if you intend to run 5s. The MMM 2200kv combo is well suited to 4s. Good lipos will get the job done on 4s. With the exception of MaxAmps and maybe Venom most of the lipos on the market will get the job done as long as they cas sustain 100+ amps.
