Pdelcast
Pdelcast's Avatar
05.21.2009, 10:58 AM
The MM has 18 fets.
In brushless mode: At any one time, a 3 FETs are channeling battery + to the motor and 3 FETs are channeling battery - to the motor. The current rating is limited by the combined amperage rating of those 3 FETs.
Brushed with reverse: Similar in concept as above, except one phases is not used.
High power brushed: This hookup does not have reversing, but 9 FETs are on all at once going to the motor + coil. While the - battery goes directly to the - motor. This effectively triples the amount of current available to the motor compared to the other two hookups. This might be useful if you want to drive 2 or 3 motors at the same time.
Hi Brian!
The MM actually has 30 FETs. 18 on top, and 12 on bottom of the main power board.
So in reversing brushed there are 5 FETs high side, and 5 FETs low side driving the motor (and they are in series -- so it doubles the FET loss)
In high power brushed, there are 15 FETs driving the motor, and only on one side. But no reverse...
Patrick del Castillo
President, Principle Engineer
