How many NiMH cells are you trying to use? And, have you disabled the LVC when using NiMH cells? The NiMH voltage may be dipping under load tripping the LVC or just dropping far enough that the ESC is "rebooting".
I'm using 6 cells nimh. So 7.2V... Yes, I have dissabled the LVC.
Well the ESC usually "stops/makes a pause" if I give full throttle a few times in little time.
