BP-Revo
BMW M Power!
BP-Revo's Avatar
05.21.2009, 11:17 PM
Run it for 1 hour doing that and then look for the metal filings... should tell you where the noise is coming from...
I don't mean something solid.
In my G2R I put a couple o-rings on one side and a small spring on the other. They can still move any which way, but this helps keep them centered, which means quieter CVD's that are less likely to pop out. Haven't had a problem yet.
05.22.2009, 01:29 AM
pull your front driveshaft and run it. if your worried about it unloading to the front just wire a shaft(allen wrench, anything) through the front cup to hold it stationary. do a couple high grip passes and see if the tickings gone. don't run much its hard on the center diff, but fine for a couple passes. that'll get you 50% diagnosed......
brushlessboy16
brushlessboy16's Avatar
05.22.2009, 06:45 AM
Thats a good idea.
Like you said- might be a bit much for my CD tho
