When in doubt, Build a Bigger Motor
brushlessboy16
brushlessboy16's Avatar
When in doubt, Build a Bigger Motor - 05.23.2009, 07:16 AM
Recently my dad's dragster engine spun a cam bearing... Right after it was rebuilt this winter, So now he decided to build up an even bigger motor :)
Its a Big Block ford 460 block, bored 4.440 and stroked to 532ci, Eagle H-beam rods, JE forged aluminum Pistons, and a .728 custom ground cam, Roller cam Bearings, Kaase Super cobrajet aluminum heads, Single plane High rise intake, Holley dominator carb running on alcohol.
Should put him well into sub 7 second 1/4 mile finally
The old setup was
470CID BBF
543 cam
stock crank
Same top end
That setup was running 8.3 1/4mi
More pics to come.
nitrostarter
nitrostarter's Avatar
05.23.2009, 12:06 PM
Well theres the problem in the first place....
N. Rustler conversion
brushlessboy16
05.23.2009, 12:07 PM
your just mad because your distributor is on the wrong side.
J57ltr
05.23.2009, 12:31 PM
So I guess that's the old engine?
Jeff
nitrostarter
NAh, its goes for looks and performance. I can hide my wires more easily.
brushlessboy16
05.23.2009, 12:32 PM
Thats the old block. other block just got back from hot tank.
Its a 429 Super cobrajet block 4 bolt mains etc :)
J57ltr
05.23.2009, 12:40 PM
Good I was fixin to say I can see the ridge and the cylinders look about shot
I got into Rc because Drag racing was just too expensive!
Jeff
