hyper tires
Doug Shelp
hyper tires - 05.23.2009, 03:13 PM
Yes they fit, now the question is what surface are you going to run on most of the time? If your a track whore like me and if your track is hard packed like clay or granit i would recomend,hole shots, sqaure fuzies,doudle dees,that new panther hole shot clone or any short firm pin tire.Also i prefer trinity Bomb one firm inserts. If your track is loose and fluffy and is watered farely regularly id run goose bumps ,step pins,bow ties or any tire with a larger longer pin to dig down through the fluff.The bow tie dosnt steer so well so i run them on the rear to get good forward bite and something like a step pin on the front.These larger longer pin tire are for me better on grass than the shorter pins.
