B4maz
05.24.2009, 02:36 PM
I haven't had any problems 360 has with bringing up saved files. One thing you can try when you bring up a saved file, go to the graph, and in the lower left corner there is a button that resets the graph to the default settings. While I go through graphs zooming and panning I get lost as to where I am and sometimes I zoom too much and nothing shows up. Try hitting that reset button to see if anything shows up. I always export the jpg and I havent had any problems. How are you exporting jpgs?
Here are some pics of data that I have from doing speed runs. I am using a V3 with a brushless sensor and a 5hz GPS to record speed.
From Fast RC
From Fast RC
From Fast RC
Duster_360
05.30.2009, 02:31 PM
Sorry for the delay in reponding, but on morning of the 25th, PC - hard drive crashed, no warning, looks like a head failure. Drive sent off for data recovery and I'm back up on a new drive waiting for data to come back.
Later same day, my primary desktop starts acting up, NAV was only able to warn me about something called Packed.Generic.200 - a really nasty virus that changes windows so nothing can be done to get rid of it, windows can't see it. Disables system restore, won't allow me to scan C: in any way, prevents SpyBot and many otherspyware/malware tools from running. I believe its purpose is to use my PC as a spambot, so basically, another PC thats toast, 2 in one freaking day! I have to "rebuild" the system after a clean install to get rid of that crap. I hope there is a special place in hell for the despicable scum who write this trash.
Thanks for the help and suggestions, but when my 150amp Eagle Tree arrived, it had a much later version of the software. I installed it and now my saved files play back fine, the data was there all along. The prob had to be with software version I received with my orig recorder. It would load the file, and show the time, but showed nothing else no matter what I tried.
Now, all is good. Has anyone tried running the recorder on a Flux?? Does it make a diff which side you hook up on??
Jeff - I'm in West Houston, near Memorial. Where are you located??
Shark413
Shark413's Avatar
05.30.2009, 03:14 PM
I have a Data Logger V3 and the V2/Seagull wireless model. Great for taking readings while testing new motor/ESC/battery/gearing combinations.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
