The Cow
The Cow's Avatar
05.27.2009, 07:38 PM
Originally Posted by Unsullied_Spy View Post
That looks great, much more work in that than I really plan to do to my Micro My DT is totally stock but I put the mid-sized pinion on it and a Losi 2s lipo and it's reasonably quick now but I'm after the power and runtimes of brushless. How well do the long can Feigaos fit? I was thinking of getting a S can and running either 1s or 2s lipo.
Thanks
Keep in mind depending on the motor Kv it will likely end up slower on 1s... However the fiegao/mamba combo with the exact same set up otherwise will likely doublt-triple your run time and be signifigantly faster to...
The long can is tight... Depending on the wheels could be to close for comfort. From the sound of your goals though you may be happy with the stubby... For my use it was very taxed, Not as bad as the excelorin but they are also much higher KV and pretty lousy to be honest in the quality department... The Fiegao is a kick ass little motor either way I would doubt you would be disapionted Just do some math to make sure you purchase the righ KV for your goals...
Heath
"from deep within the barn doors"
** COWRC.COM **
