Finnster
KillaHurtz
Finnster's Avatar
05.28.2009, 05:59 PM
Originally Posted by Unsullied_Spy View Post
Those PPs are comparable to Deans, but they make PPs MUCH larger. I've seen them over 100 amps and I'm sure you can get bigger. The military uses those on aircraft, tanks, etc. so they can't be too bad (military stuff is more cheap than good, but...)
We have a elec pallet jack @ work that has some powerpoles that are the size of a deck of cards each. They are rated for several hundred amps and work well enough. Don't know if you want those on your car tho
