Speed
exawatt
Speed - 05.28.2009, 09:41 PM
hey speedemall,
looks great! my neighbor just brought his inferno over to me and wants me to turn it brushless for him. how does yours run? what kind of speeds. i would be using a MMM, Neu 1515 1y, and 5s lipo. very similar to yours. just wondering how you like it so far.
If you run it with the setup above it will not be drivable. All it will be good for is destroying tires and screwing around in a walmart parking lot when its empty(hahah).
I will have a single speed diff this weekend and will be taking it to the track to see if it helps.
Ryu James
Ryu James's Avatar
06.08.2009, 03:19 PM
so i think running a 2 speed would be cool but it sounds like it is total overkill. what is a good, drivable, fast setup? i am thinking of just going single speed with the Neu 1512 2050kv on 5s 2600mah. would this be a decent setup? also, what kind of diff can i use for the center diff? do i need to run just a spur gear or would it be ok to acutually run a differential?
Jammin SCRT10 Neu 1512 1y
inferno single speed
exawatt
inferno single speed - 06.08.2009, 03:58 PM
i used a inferno diff kit from the 777sp2 and the 46t plastic kyosho spur. all worked well but you need to get the longer front center shaft. i dont remember what the partnumber is but i think it was 110mm i can check when i get home.
Ryu James
Ryu James's Avatar
06.08.2009, 09:40 PM
perfect. can you let me know on that. i have decide to just run single speed so i knew i would need the longer drive shaft. even if you dont have a part number just the what model its from would help.
also, i dont have my gt2 yet. just ordered thru amain. i am wondering what the pinion shaft size is on the front and rear gear boxes. you know that shaft that comes out of the gearbox and connects to the drive shaft. is it 5mm or 8mm?
