05.28.2009, 10:58 PM
To be clear; does the vehicle have a motor on each axle, or both motors attached to a motor plate on a central transmission. If the latter, syncing may be an issue and would be better served with a single motor. If the former, it should be possible since there is no mechanical syncing that needs to be done since they don't share a common spur.
