Unsullied_Spy
Unsullied_Spy's Avatar
05.29.2009, 01:57 PM
Originally Posted by hemiblas View Post
I have had my supervee flip a couple times and almost sink too. I'm a bit scared to run it now. Putting some 8000mah lipos in there and knowing they could find a home at the bottom of a lake doesnt make me feel so well. So wouldnt going to 3S and gearing down get you much better temps? Maybe enough to let you run a little longer without the water cooling?
The SuperVee likes calm water. Fortunately most of the ponds where I live are very still. It's always windy here, but the ponds usually aren't too bad and that helps with keeping the SV hatch side up.
I may be gearing up as well as going to 3s which will make them run hotter, the water cooling will be essential.
05.29.2009, 02:03 PM
Mine ran fine in choppy water. Had to get the cg and trim tabs setup correctly though. Adjusted the strut as well. Plus going to a x624 prop helps a bit as well with prop walk.
