05.29.2009, 06:54 PM
Buy new wheels....
Unsullied_Spy
Unsullied_Spy's Avatar
05.29.2009, 07:37 PM
Buy new wheels....
He said he didn't want to buy new ones. I'm sure he's short on cash and wheels can get pricey.
Originally Posted by ZippyBasher View Post
put the hex in there and use a 2 part epoxy to glue it in place and fill the gaps. (it'll still be able to be pulled out later).
Worked for my 14mm RPM Wheels...(Metal Hex)
That's the best bet, IMO. You should still be able to get the wheel off later and it should hold plenty strong until it needs to come off. Either that or find a nut that will fit properly over the hex and glue that nut in. If you can't find a nut that'll fit, get a 17mm socket (should be able to find a cheap one) and cut the end off and glue that in.
