Stregone
05.29.2009, 11:43 PM
Some people simply seem to be cursed, while others can get anything to work. Hopefully it's just an isolated incident.
IIRC, there was something bad about setting 0* timing on the 150A version where it would burn something up. Don't know if it applies to this particular ESC (I imagine it uses the same firmware), but is it possible that while messing around you set the timing to 0* by accident?
I checked the settings with the programming card and everything appears to be on the default setting still.
I'm curious, why would 0 degree timing burn out an esc, isn't less timing supposed to be easier on the motor and esc?
