nitrostarter
nitrostarter's Avatar
05.31.2009, 02:58 PM
What is your setup in the rustler? The MM should be able to handle it easily! What electronics and all are you running? Something sounds fishy....
N. Rustler conversion
05.31.2009, 03:01 PM
Bad servo? It may be overworking the MM bec?
I have had great success with MM escs, probably had 10-12 of them and they have held up to almost everything that I could throw at them (save for a 7xl on 5s...)
A RC Dude
A RC Dude's Avatar
05.31.2009, 09:04 PM
Servo's just fine. and i have the MM bec disabled to reduce heat and get the servo to move faster.
My gearing is 15/90 and temps haven't been very high. my first MM ESC hit 250 a couple times and the motor hit 230 a few times as well and nothing ever happened. it ran at those temps for a couple months before i got the FLM tranny case and got the temps down a lot. after that it ran for about another year before the ESC went out. got a new ESC and it ran for about half a year before the motor failed out of noware and in return the ESC went with it. i got the motor and ESC replaced at the end of last summer and it's run well since them, even with 2 trackpowers and a 9xl in my maxx. the water damage to the stock reciever mad me replace it with a futaba receiver and it ran fine with that setup for a wile and then just now went out again
