Over_revO
05.31.2009, 10:20 PM
Thx man! appreciated!
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.01.2009, 01:23 AM
Absolutely no offense to you, this is just my opinion.....
COMPLETELY USELESS, RETARDED, BORING, AND EXPENSIVE
again, just my opinion.
and ya, your lower speed drive ability is going to be in the toilet; you would need large battery for sure.
Over_revO
06.01.2009, 06:02 AM
What some of you may dont understand is, i posted here to know if its possible, if it will overheat or not, its not like im trying to tell you its possible, im here to know if it is, so telling me you would not like the setup ....is useless...
If you guys think it would not work, and overheat, i will not do it, simple as that...
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
06.01.2009, 10:38 AM
i don't get it. why are you guys giving this guy so much guff?
a few years ago, i heard the same BS when people were talking about dropping 6S in their e-maxxs. it can't be done. it's too fast. it's useless. blah blah blah......i think it was the laziness of people not having the technology handed to them on a platter that's making them so against it.
because when the MMM came out, you saw tons of 70+mph trucks with tons of people saying how great it was. the bashers were all but hushed.
can it be done? hell yeah it can be done. I've seen ofna buggies over 100mph with the same method. get the pistix and the hv-110 and drop some cash on some 30-40C lipos and you'll be golden.
if i'm not mistaken, Nic Case went 161mph with that same ESC. it'll provide the means for sure. the 1527 or 1521 will provide the power. just make sure you keep in mid you might need a custom motor mount because the mounting holes are larger spaced apart. Rc-monster Mike might be able to fabricate one for you if you ask him. (he's also the owner of the site)
http://www.offshoreelectrics.com/products.php?cat=42
Also, those motors usually require an 8MM bore pinion. however, offshore electronics rc can special order them with 5mm shafts. it could take several weeks to order though...they also carry the pistix.
http://www.offshoreelectrics.com/pro...rod=msw-pistix
instead of saying how retarted it is, encourage the guy...geez ....jzmaxx did over 80 with one of the heaviest MT that's available. an 80mph truggy is definately do-able running cool.
good luck Over_revO
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
zeropointbug
Z-Pinch racer
06.01.2009, 01:46 PM
hey hey hey, I never said he shouldn't do it.... I said that was my opinion.
No one said 6s was ever too fast btw, the only reason people said that, is because everyone used 2000Kv plus Fiegao motors... which obviously, is too fast and hot for those motors.
"instead of saying how retarted it is, encourage the guy...geez ....jzmaxx did over 80 with one of the heaviest MT that's available. an 80mph truggy is definately do-able running cool."
Okay, you're right.... good luck man on getting to 80mph, hope you don't crash at those speeds and destroy all the expensive equipment in the truck.
Alright, instead of using different controllers, what about using twin motor system? Maybe dual MMM running 1512 Neu motors? Or maybe a better option, dual MMM running T8 motors? Like 6s on the Truggy 1550Kv model? That way, it's not overpowered, still has more than enough power to get to 80mph with wheelies, and will run relatively cool. Just another option.
DwightSchrute
06.01.2009, 02:03 PM
i tried the dual MMM before, and i tore up the transmission badly in about 30 feet with the neus. it just had soooo much torque...even with 100% punch control.
twin feigaos had better results but i could never get it up to full speed. it was simply too much power for me.
here's a pic:
however, i agree with you. if i could have gotten it to work, i'm confident it had the power to do atleast 80.
06.01.2009, 02:10 PM
I really do not see the issue with making trucks go fast. Forward weight distribution, low stance, very limited suspension (no droop) and a front wing should do the trick.
Something like the erevo body to make it more aerodynamic. At those speeds tire setup will be more critical than anything else.
Setting alot of neg expo on the radio will help with startup issues, and being careful with the throttle during the run as well.
Not saying that this would be anything other than a straight line vehicle and most likely good for a handful of passes at a time.
Last edited by lincpimp; 06.01.2009 at 02:18 PM. Reason: Its raining Men, hallelujah its raining Men!
