riverat1540
riverat1540's Avatar
06.02.2009, 07:45 PM
the gears will mesh fine if u can get the motor close enough which should not be a problem, but as a warning u will be geared pretty high if u dont do the diff conversion as well and it will seem to run fine and really fast but that is how i snapped my motor shaft as it will put much more strain on the motor. i was at a 14 t pinion but u are not far off even with an 11 if using what u plan to do i suggest a slipperential or the diff conversion, but it would help if i knew what kv your motor was,lol
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
