Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.03.2009, 02:53 PM
Originally Posted by Byte View Post
Oh ok, I thought the Servotester would get his power from the ESC (Like a normal receiver)
Well, thank you for your help Metal!
If the esc has a bec it might be able to get it's power from it, but most likely you'll need to hook up power to one of the two inputs from an external bec, power jacked off the esc lead (make two wires coming from the esc, one for the input and on for the bec output) or hook it up to your main batteries if you aren't running more then 22v. I'm going to hook mine up to one of my 12v lead acid batteries.
