MetalMan
MetalMan's Avatar
06.07.2009, 05:50 PM
It is easier IMO to use the 3rd channel if you have a radio which allows the 3rd channel to operate off the trigger (but independent of the 2nd channel). This way you can adjust the brakes without touching channel 2. Some radios would call this brake mixing.
But a y-harness on channel 2 will work as well, just gotta make sure the Pistix goes between the y-harness and the ESC.
