06.08.2009, 05:01 PM
If the lst clutch will fit on the tekno clutch adapter then you can use it with the 2 speed screw on pinions that Mike sells.
I would just get his 2 speed adapter and do away with the clutch.
I ran an IGT clone with a small 1509 sized motor with the 2 speed and a modded 4-tec clutch bell. I had alot of issues with the clutch and ended up with a custom flywheels and al clutch shoes. Should have gone with a pinion adapter. I used mech brakes, and mixed them on the 3rd channel with the throttle channel.
If you plan to run more than 40mph with the IGT get a larger motor than the 1512. It will run cooler. Not sure if your batts will keep up to more than 40 though.
