Help me upgrade my E-Maxx tired of braking parts!
Chris911
Help me upgrade my E-Maxx tired of braking parts! - 12.31.2005, 12:18 PM
I love my E-Maxx and i love to have the slipper clutch all the way in the truck will flip over backwards and is so much more fun!
I keep braking half shafts (i've broke 2 already) and i'm sure the extra stress will brake other parts in time so i would like to upgrade all the shafts to something stronger and any other parts that you guys think will brake sooner or later. The truck is all stock there is so many parts out there i don't know what will fit and what wont. Can you guys post some links to some half shaft upgrades that will fit the stock e-maxx it is the new e-maxx not the older one.
What about the diff and trans can they handle much power? I will probably get a better motor some time so i would like to go ahead and upgrade the stock parts to handle the extra power.
Sneeck
RC-Monster Custom
Sneeck's Avatar
12.31.2005, 01:13 PM
First of all, welcome on the forum's!
What your looking for are cv's from tranny to diff's. Unlimited engineering has them in titanium that won't break, Mike can hook you up with these.
I don't know what stuff you want to upgrade, what budget you have, intention to go brushless in the future and if you want to keep the truck as much stock as possible. So if you can be a bit more specific I can help you further.
  Send a message via MSN to Sneeck
boss 302
12.31.2005, 01:21 PM
http://www.rc-monster.com/products.php?cat=47
this page has all the hopups u would need and if dont see a hopup you want mike could probably order it for u
Chris911
12.31.2005, 01:34 PM
I would probably go brushless in the future and maybe a differant Chassis and suspension if i had trouble with the stock ones braking from the extra power.
Budget wise $500 for now. For right now i really just want to run it with the slipper clutch all the way tight without braking parts. I checked out Unlimited engineering and i don't really know what parts will fit the e-maxx i have there site says SuperMaxx whatever that is.
Can you post links to the things i need?
Thanks.
coolhandcountry
coolhandcountry's Avatar
12.31.2005, 04:13 PM
Welcom to the forums chris.
Center cvds
6mm cvds need 2
These are a little stronger
You may want to get these for you transmission. Make it a lot stronger.
You may want to consider the 1/8 buggy diffs later on. Make a really tough drive train.
Peace!
Country
Help support the
Rc-Monster
Buy here
Chris911
12.31.2005, 04:35 PM
The Center cvds........ one looks longer than the other? On my truck they look to be the same.?
6mm cvds need 2 ........in the info it says "Stock width suspension CVDS are also available "?
Do you think if i installed all these things i could trun my slipper clutch all the way in without braking parts?
Chris911
12.31.2005, 04:43 PM
Is this the diff your talking about?
http://www.rc-monster.com/proddetail...zerdiff&cat=47
or this
http://www.unlimitedengineering.com/...re/13540B.html
coolhandcountry
12.31.2005, 05:16 PM
If you run the 6mm cvds and metal idler gears with the titanium center shafts. The only part i would worry about would be the diffs. If you running the titans I wouldn't worry about them but so much. The pic for the center shafts is used in all of the choices. The bottom one is the one I was talking about. You can email mike and he can hook you up with all the stuff you need. You may want to look at running the flm hybird for the 1/8 buggy diffs if you bash alot. I run the 6 spyder gears with no problems yet.
Peace!
Country
Help support the
Rc-Monster
Buy here
Sylvester
Sylvester's Avatar
12.31.2005, 05:29 PM
The center cvds shown were the ones for extended chassis, are you gonna run stock length chassis? If so the MIP seem to look pretty good.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
boss 302
12.31.2005, 08:03 PM
mip's work well for stock length just make sure u get the emaxx ones not the tmaxx ones they are different lengths
Chris911
12.31.2005, 08:52 PM
What about a diff that will work with the MIP's or will i be ok with the stock one. Later i will go brushless.
boss 302
12.31.2005, 08:53 PM
the mips work with stock diffs
Chris911
12.31.2005, 08:56 PM
But will the stock diffs breake with the slipper clutch tight?
boss 302
12.31.2005, 08:59 PM
mine havent yet and i have the slipper tight
Sylvester
Sylvester's Avatar
12.31.2005, 09:06 PM
They shouldnt break too fast if you dont put too much power through them, how many cells are u gonna run?
Losi 8ight e
